I finished the gate install and moved to finishing the cable install for this gate. I had to locate and drill a hole thru the firewall. I chose the location on the pilot side right in line with the gate.
I added a firewall passthru. I had this one left over in inventory. It is a bit complicated but worked well.
I added a couple of adel clamps per plans.
I cut the cable to length and twisted the end around the part of the gate that opens, all per the drawings.
