RV-7A Construction Log
Date:  4-18-2017
Number of Hours:  1.00
Brief Description:  Baffles 18 Snorkle
Time to put on the snorkle. You'll see the problem here. I used a roll of tape in the throttle body to hold the snorkle centered. Then I held it to the ramp and trimmed the top until it fit flush against the bottom of the ramp. Later i trimmed off another 1/4 inch to make room for the pieces that hold up the snorkle. I marked the bottom of the ramp and trimmed.
You can see below when I trimed out the space for the air snorkle I don't have enough material forward nor to the right. This is partly due to trimming it earlier. And also the snorkle seems to fit way to far to the left or outside. Anyway, I'll show my solution here, but I am thinking about ordering another ramp from Vans and doing this over. It costs only $16.
