RV-7A Construction Log
Date:  4-18-2017
Number of Hours:  0.50
Brief Description:  Baffles 10 DO NOT TRIM LEFT RAMP
I trimmed the right ramp to fit within the cowl. Then I trimmed the left ramp. BUT DON"T. STOP. If you are doing the horizontal induction with the snorkle DO NOT TRIM THE RIGHT RAMP.
Later you'll see I have to rework this. At this point I have a solution, but I am thinking about ordering a new ramp part and starting over. You cut out a big hole in the left ramp for the air. Then you trim the fiberglass to match. I had read you need to get the ramps set then do the snorkle, but this is wrong. Leave the left ramp alone until you install the snorkle. And don't bother with the bend on the left ramp because with the air hole in it, it doesn't matter.
Trimmed Right Ramp
Trimmed Right Ramp
Do snorkle first
Do snorkle first
