RV-7A Construction Log
RV-7A
Baffle 6 Corner re-enforcement
I decided to add an angle aluminum to the corner to help re-enforce it. I notched out two places where there is a doubler and the stiffner. I sanded the corner off so it would fit into the rounded corner of the bent aluminum sheet.
Notched
Drilled
Ground off corner to fit radius
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
