RV-7A Construction Log
Date:  4-18-2017
Number of Hours:  0.50
Brief Description:  Baffles 14 Front clips
I made a few clips for the front baffles. These are match drilled for now. I was also having trouble with the right rear baffle not fitting right. I discovered the flange on the bottom was hitting a tube, so I cut some of the flange off. it is better now. But later I will have to turn the clamp around to get the scew part out of the was.
Tube and clamp interference
