I built up the baffle ends before glueing in any of it. finally when I had the baffles fitting fairly well I glued them in. Mfg plan says to be sure and install the cowl during the time the resin hardens so that it keeps the right fit. After the baffles are glued in the cowl is stiffer.
For glue I use resin with some fiberglass chop in it.
