RV-7A Construction Log
Date:  12-10-2016
Number of Hours:  1.00
Brief Description:  Cowl Instal 11 Fitting Upper Cowl
I drilled the three holes in the forward overlapping area Photo 2 below, but I end up drilling these again later, because the aft most hole hit the teeth of the engine gear. These three holes need to be in the first 2 1/4 inches, not further back. Drawing is wrong.
