RV-7A Construction Log
RV-7A
Cowl Instal 10 Fitting Upper Cowl
I cut the bottom first per plans. Then reinstalled and marked and cut the sides.
I made sure the upper cowl was level with spinner and drilled the holes on the lower cowl bottom.
Then I drilled the sides. I used my dril guide to space them all 1 inch.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
