RV-7A Construction Log
Date:  12-10-2016
Number of Hours:  1.00
Brief Description:  Cowl Instal 10 Fitting Upper Cowl
I cut the bottom first per plans. Then reinstalled and marked and cut the sides.
I made sure the upper cowl was level with spinner and drilled the holes on the lower cowl bottom.
Then I drilled the sides. I used my dril guide to space them all 1 inch.
