RV-7A Construction Log
RV-7A
Prop Install 2 Prop Backing Plate
You have to cut a pretty big hole in one of the plates to make it match the other. I used the fly cutter on the slowest speed by drill press will do. Worked fine and accurately.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
