RV-7A Construction Log
Date:  12-5-2016
Number of Hours:  1.00
Brief Description:  Prop Install 1 Prop Backing Plate
Time to do the cowl. Which means mount the prop. Before proceeding I read a bunch of other builders logs, and read topics on the Van's Forum. Then I studied the drawings and discovered that when I bought my Finish kit I was doing fixed pitch prop and so I had the wrong backing plates because I bought a constant speed prop. I return the wrong parts and Van's sent me the new parts and I got a credit. They are pretty good about that.
First thing to do is put the two backing plates together into a single part; an assembly part. It was kind of fun to do some sheet metal work and riveting again.
