Brief Description: Red Cube Fuel Flow Sensor 4 Fire Sleeve
I tightened the fittings and closed the sleeve with tie wraps. The RedBox is now installed. It is NOT attached to engine but is held by two Adel clamps on the hoses a few inches on both sides of the RedBox. Seems pretty stiff. The sleeve gives some cushioning against the engine block. I like that.
