RV-7A Construction Log
Date:  9-14-2016
Number of Hours:  0.25
Brief Description:  Cables 7 - Interference with pressure hose
The fuel pressure hose interfered with the mixture cable. I thought why did Van's put the firewall hole here making both the pressure hose and the cable hole aligned? So I took off the pressure hose and moved it to the other port on the pilot side and plugged the co-pilot side. Seems okay now.
Moved to pilot side
Moved to pilot side
