Routed the prop govenor cable. Remember I had to turn the cable to get it onto the bearing because I attached the bearing on the bench. Turned out to be a B()&*(*&. I had to use tiny plyers and turn them over and over and over. I could't turn the cable with my fingers. I think I got it in all the way. It stopped turning after a while. You can see the number of threads left on photo below.
