RV-7A Construction Log
Date:  9-14-2016
Number of Hours:  0.50
Brief Description:  Cables 3 - Throttle Routing
Routed the throttle cable. Notice I had to put the firewall plug backwards because there wasn't room for the cap due to interference with the engine mount. Backwards is okay.
My throttle hole location is only 1/8 to the pilot side and down 1/8 from the Van's location. I moved it because of intereference with the doubler for the fuel line. I would say that is as much leaway as you've got. Any more and it would interfere with the motor mount.
Wired the firesleeve onto the cable.
Fire sleeve on throttle cable
Notice hole location.
No room for cap on FWF side
