RV-7A Construction Log
Date:  9-16-2016
Number of Hours:  1.00
Brief Description:  Mount the Engine 6 Mixture Linkage
took awhile to figure out where to bolt on the mixture brackets, but finally did. This is per drawings.
The arm on the mixture was clocked wrong similar to the Prop Govenor. So I loosened the bolt and put it where it needed to be. There are little teeth that hold it in place.
