Then I went bolt to bolt and tightened them, each a little at a time and drew the engine into the mount. Plans say you can't get a torgue wrench on the nuts, which I couldn't. So I tightened them until they stopped. there was an obvious stop.
I backed off the each nut and added a second washer so the cotter pins would be low on the castle nuts.
