RV-7A Construction Log
RV-7A
Cables 1 - Firewall Penetrations
I'm thinking about mounting the engine onto the fuselage. But before I do, what else should I do.
Decided to drill the cable holes thru the firewall and install grommets. I'm going to use the round blue grommets for the three major cables
I drilled the throttle hole, the prop hole, and the mixture hole.
I used a hole saw to drill them 1.07" in diameter. This is 1 1/16 drill.
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
