RV-7A Construction Log
RV-7A
Throttle Body 1
The plans lead next to the fuel pump. Mine is already installed on the new engine. So all I did at this point was install to fittings.
Some fittings into the engine received Loctite567. These fittings into the fuel pump also got Locktite. Other rittings for fuel stuff get fuel lube.
Fuel In
Fuel Out
Fuel Lube
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
