RV-7A Construction Log
Date:  9-13-2016
Number of Hours:  0.25
Brief Description:  Throttle Body 1
The plans lead next to the fuel pump. Mine is already installed on the new engine. So all I did at this point was install to fittings.
Some fittings into the engine received Loctite567. These fittings into the fuel pump also got Locktite. Other rittings for fuel stuff get fuel lube.
Fuel In
Fuel In
Fuel Out
Fuel Out
Fuel Lube
Fuel Lube
