One of the fittings in from the oil cooler was already installed on the new engine. Lucky. This is the fitting the Van's plan says is difficult to install without removing a magneto.
I installed the fitting into number 3 cylinder for the manifold pressure. Cylinders are numbered front to back with even on the pilot side and odd numbers on the co-pilot (right) side.
