RV-7A Construction Log
RV-7A
Engine Preparation 13 - Oil Pressure Fitting
Now it is time to do some prep work to the engine.
First thing on Van's plan is to install a fitting for oil pressure. I found the port as described.
All fittings going into the engine will get Locktite 567.
Rear Facing Port
Use Loctite 567 on fitting
Face it outward and down 45
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
