RV-7A Construction Log
RV-7A
Engine Preparation 6 - Cabin Heat Valve
The heater valve for cabin heat is the next part to provision on the firewall. This needs a 2 inch hole in the stainless steel firewall. This took a while with a hole cutter.
Secret to cutting stainless is go slow, use lubricant, keep bits cool.
I painted the heater valve Lycoming Grey too.
Clamped wood to back of firewall
2 Inch hole saw. Smooth hole
Painted vent
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
