RV-7A Construction Log
Date:  5-3-2016
Number of Hours:  1.00
Brief Description:  Fuselage Painting 7
Finally to paint the bottom. I taped off the whole top area using some plastic. That's why you can see the white thru it. I cleaned it of course. Oh, I also hand sand the primer with #400 #600 or #800. I use whatever I have fresh. Makes the primer smoother.
I'm not telling about the blotchy primer spots that spent a lot of time sanding and respraying. That wasn't per plan, but !@$% happens.
The blue metalic sprays pretty well. Doesn't seem to run as much as the white. You are not suppose to polish metalic, so that is why I do it last. If blue gets on the white I can polish the white. But not vica versa.
To date I have 5 gallons of paint used. It is not all on the airplane because a lot of it hit the floor or went up the ventilator.
Taping it all off to spray bottom
Spraying blue on the bottom
It took about a gallon
