RV-7A Construction Log
Date:  1-3-2016
Number of Hours:  1.00
Brief Description:  Wing-Tips 2
The tips don't need etch primer. I held them with a stand up thru the center. For every part I have to figure out how to hold it so it can be painted with being touched. And I like to be able to spray the paint flat rather than vertical because it lays down smoother.
After spraying the primer I could see some more little pin holes so I filled them with glaze too.
Sprayed primer
Sprayed primer
Filled pin holes
Filled pin holes
