RV-7A Construction Log
Date:  11-5-2015
Number of Hours:  1.00
Brief Description:  Horizontal Stabilizer Painting 1
Same preps had to be done for the HS. I peeled all the blue celephane off. I ruffed up the skin with grey scotchbrite. And this time I swiped some glazing compound on all the holes on the top of the HS to see if I like the painted result better. Recall the elevator painting showed me that paint doesn't get in around the flush rivets very well.
I didn't make the rivets flush with the skin using the glazing compound. I just did a tight swipe to fill the gap around the flush rivet head. Well see if this gives a better result.
Then I also had to make a fixture to hold it. In this case it is a stand 30" off the ground.
Oh and I had to remove all the grey spray can primer. I used acetone and it wipes off pretty easy but ruins a lot of rags. Rags are cheap but what a mess. The stand also holds the HS flat and I plan to put the last coat of paint on thick and wet and want to keep gravity from making runs.
Glazed the rivet holes
Stand to hold the HS
Flat holding
Flat holding
