RV-7A Construction Log
Date:  11-2-2015
Number of Hours:  1.00
Brief Description:  Preparing Elevators & priming
I pulled all the blue celephane off. Then scuffed them lightly with grey scotchbrite. Then all the primer on exposed surfaces had to come off.
DON"T PRIME SURFACES THAT WILL BE EXPOSED. You'll end up removing the primer so you can reprime with the paint system primer.
Then I have been lucky to be offered a paint booth for a period of time. The paint booth is over 50 feet long and I'm using just one end of it. But it has heat and good cross flow of air. It makes painting a lot easier.
I mounted the elevators on their fixture poles and clamped the ends to a 2x4 to keep them stable. The air coming out of the spray gun is sufficient to move them and that makes painting difficult.
