For painting I bought a Devilbiss a long time ago and am now using it. It works great. It is about a $200 gun. It is their Finish Line FLG 3 model. I also bought a 1.8 nozzel for it.
Then recently for painting I bought the TEKNA ProLite. It is distributed by Devilbiss. I used one at the Sherwin Williams painting class. Used it today. It really makes a nice spray. It is about a $400 dollar gun.
I think this is plenty of quality in a gun.
Also notice I'm using the digital pressure gage made by Devilbiss. The guns both have about a 15 psi drop thru them. So to get a 10 psi at the tip or cap, you need an input pressure of 25 psi. So when you read paint should be sprayed at 10 psi using HVLP that is cap pressure so you have to set the gauge at 25 psi.
And both guns use a filter at the gun. This is a must.
