RV-7A Construction Log
Date:  5-17-2015
Number of Hours:  0.50
Brief Description:  Tail Light 1
I'm doing a lot of pondering about wire routing, connectors and securing wirings. But time to turn ponders into action. I'm starting aft and moving forward.
I decided every component needs to have a connector so if the components needs to be replaced there is a connector within close proximity.
So I cut the leads on the tail light to just a few inches and put on a connector. I'm using a 0.062 Molex connector. They don't have clips but they do have knobs that somewhat lock the two halves together. I hope these are okay. If not I can always put a zip tie around them later.
I got a three strand wire and put the female connector on it. I'm putting male connectors on all components and femaile on the receiving wire.
For trim tab I'm just using D-sub pins and will cover them with shrink tubig later when I install the servo. The servo wire is a 5 strand 24 gauge from Stein Air
I've started a spreadsheet of wires. This is 20 gauge. I'm labeling all the wires with white shrink wrap.
I will do a local ground on this light. Then three wires go forward. Power for strobe. Power for position. And synch wire for the strobes that synch with the wing tip lights.
Female connector for light
Male connector on light
Trim tab connectors
Trim tab connectors
