Brief Description: Main Gear Intersection Fairings 7
One of the last things to do is make sure the opening around the wheel is sufficient. I took the gears off the airplane and put them on the bench. I re-installed the fairings and used a 5/8 thick block to mark clearance around the tire and trim the fairing accordingly. Now the holes are sufficient in clearance, and about the same on both gears.
