I found the pant brackets and finished them per drawing. Becareful not to make the slot any larger than the dimensions because it should fit without any play over the washer on the axle.
I put a 3/4 inch block on top of the wheel per plans for clearance.
I made a horizontal line on the pant with tape. I found horizontal by taking the most forward and aft spots and connecting them. I hope that counts.
