RV-7A Construction Log
Date:  2-9-2014
Number of Hours:  0.50
Brief Description:  Wing Bottom Skins: Left Inboard 2
I pushed forward and rivetted on my first wing bottom skin. This is the inboard left wing. Then I moved to the outboard skin. As I progressed I saw how to work top down and from inboard edge to outboard edge.
I sas able to buck all the rivets without an asstant. I reached up inside. Recall from earlier rivetting after you get going you can feel the rivet squash and you can just feel if it set right. I did use a light and mirror to check, but going by feel became the process.
Reach up from bottom to buck
Start at the rear spar
Move from inboard to outboard
