Brief Description: Wing Tips: Red Green Nav Lights 3
I bench tested the lights. The work fine. The flash together like they are suppose to. Very bright. No power unit needed. Only 20 gauge wire needed. No noise. Cool.
I'm going to have to make something cool to go under the light and inside the tip cut out. I think aluminum polished sheet would look good. I've seen it on other RVs.
