Brief Description: Wing Tips: Red Green Nav Lights 1
I'm using Aveo Engineering LED position lights. These match my tail light. The cost $850 bucks. Ouch. I found a template on one of their marketing cards so made a backing plate to match. I glued the backing plate to the tip and secured it and the platenuts with #4 screws. I didn't rivet it because I can't use the squeezer and I'm afraid pounding it will hurt the fiberglass. I might change my mind and use pulled rivets. We'll see. I glued it similar to the strips using resin, hardner and flux..
