RV-7A Construction Log
Date:  8-21-2013
Number of Hours:  1.00
Brief Description:  Wing Tips: Adding Plate Nuts 5
I've been thinking about the order of things for drilling the tip to the wing. I've gotta consider:
Drilling matching holes
Having the reinforcement strip drilled also and mounted to tip, or not
Making holes full size
Counter sinking tip holes for flush rivets to hold the nutplates
Having the strips fall off if I don't glue them well enough (which they did).
So I glued the strips in place with tbd.
Later when I match drilled they fell off. I finished drilling and reglued them with my marine resin and hardner with a little flux added and they stayed in place fine while riveting on the platenuts.
Had to order strips from Vans
Glued in place initially
Lots of fun little clamps
