Next, after the Pitot Tube is to finish the Wing Tips. I pulled the tips and clecoed on the bottom skins. And I set the ailerons to neutral using the tool I made a long time ago when I first built the wings.
You might recall you using the tooling holes and a straight edge to line up the holes with the aileron tip. And that is neutral. the tips will be made to match this neutral position.
