Brief Description: Horizontal Stabilizer, Front Spar
Worked with the Ribs and bulkheads. Modified per plans. Countersink HS710/714 (Drilled out) after some testing on scrap.
Assembled Left side Horizontal Stab; Cleco'ed the HS601PP Skin on. Check fit for HS00006 and HS00005. Noticed a little 'bump' on the skin after I clamped it down from the area of the HS710, will check it out tomorrow.
