Brief Description: Wired the flaps controller with the actuator
My flaps are working! (once I put on the wings). I wired and connected the flaps controller in the center console, to the flaps actuator motor, and also the previously installed position sensor. I click the top "UP" button, and the flaps slave arm moves back, which when connected to the flaps, would push them up. Then I click any one of the three flaps positions, and the flaps slave arm moved towards the front of the plane, which will lower the flaps, the thrid position moving it forward the farthest.
I'm sure there will eventually be some tweaking on these positions, but the default positions are good for now.
