Project Blue Angels SeaRey
Date:  9-18-2013
Number of Hours:  4.00
Manual Reference:  None
Brief Description:  Wired and installed the center console
I figured it was time to permanently install the center console. A lot of wires run to this part, but wiring was relatively easy with all the work and labeling I previously did.
After connecting all the quick-connects, I sat it in place, then installed a support bracket to the back of it and secured it to the bulkhead. I then installed the map lid with a hinge. I pulled the 25a circuit breaker to the gear, because I have this fear of the gear trying to retract the first time I power it up… that’s not how I want to find out that something was wired backwards, with the plane sitting on the concrete on its bare belly.
Connecting all the previously installed wired quick-connects
Map pocket lid and rear support installed
Final look installed
