Project Blue Angels SeaRey
Date: 1-31-2013
Number of Hours: 3.00
Manual Reference: 17.23
Brief Description: Section 17, fitting the pylon side panels
Didn't get a whole lot of real progress in today. I did confirm that my golf clubs fit nicely in the baggage compartment, with room for other luggage, so that's something there.
I began fitting the pylon side panels. I first trimmed the bottom to follow the flow of the turtle deck. I then attached the top pylon angle to them with Clecos. When I got them in place for a test fit, luckily I was thinking ahead and wondered how I'm supposed to get the hoses and wires to the engine with the pylon angles in the way. Well, turns out that the manual didn't state which way they should go, and figured out that I had them backwards. Yes, the pylon angles are riveted to the inside of the covers, but the angles are supposed to point outwards, not inwards. Good thing I hadn't riveted them yet, because it was an easy change at this point to turn them around to where they should be.
Golf clubs fit... check.
Initial pylon cover fitting and trimming.
The top pylon angle on the wrong way!
