Brief Description: Completed section 25, still working 24, tailfeathe
Permanently installed the gap seals on the elevators, and went ahead and attached them to the horizontal stabilizers, with cables attached. Installed the control horn on the elevators. These are now done and ready to install on the plane.
Each end hinge needed a 1/8" plastic spacer installed to get everything to line up correctly.
Gap seals riveted on.
The cables that attach between them are attached, because it would be a pain to do later.
