Project Blue Angels SeaRey
Date: 4-3-2013
Number of Hours: 4.00
Manual Reference: 20.1 -20.3
Brief Description: Began section 20, turtle deck final assembly
Began section 20, turtle deck final assembly, cutting the cabin windows. I actually was going to skip this section and work on the turtle deck bulkhead arch support, because I couldn't stand the thought of cutting into my new paint job yet, but when I began with the arch, I figured out that I could really use a big hole there to reach the drill through, so a cutting I went. This was nerve-racking, with a $10k paint job. The manual says to cut these after painting, so no overspray gets in there, but I would much rather have just cut before, and trusted that the paintshop knows how to protect for overspray.
After I made the window template, and marked where to cut with a dry-erase marker, at least I had the bright idea to use masking tape outside the area to cut, to protect the paint, and give me a more defined edge to cut for. Smartest thing I did all day. Good to have this part out of the way.
I got the cutting started with a Dremel cut, just big enough to stick a knife through to cut the carpet and then insert the jigsaw blade. The blade marked "smooth metal" worked best.
Template placed 3" over, 4" up.
Painter's tape to protect that paint job.
There's my hole. Other side turned out even better. The actual window gets installed much later.
