Project Blue Angels SeaRey
Date: 5-5-2013
Number of Hours: 3.00
Manual Reference: 31.8 - 31.10
Brief Description: Section 31, motor assembly, fuel sump
Section 31, motor assembly, installed the fuel sump. Part of preflight, you've got to check for any water in the bottom of the fuel tank. I installed a bulb (with on/off valve) I can use to pump some fuel through a sump drain, and into a glass for inspection. I located the drain close enough where I could easy squeeze the bulb and hold a glass under the drain. I might end up wishing I located it back a little farther, because where it's at, any drippage will get on the paint where the step flares, but it would have missed that if placed another eight inches back, but then I'd be reaching for it more..
I located the sump drain right next to the bilge drain.
Where it is in relation to everything else.
Bulb is just ziptied in place, until I create a nicer mount for it.
