There will still be more work involved in hooking up the complete brake line system, but I needed to hook it up enough to be able to get the wheels on, since I'm running the brake line internal to the gear leg. I ran the 1/8" brake like through a black plastic sheath, and clipped it to a bolt to protect it. That bolt was an AN4-15A, but replaced it with a 16A to accommodate the clip. I added one washer to each bolt up front for alignment, and it seems to be about right.
Running the brake line through the hole I previously drilled
