Project Blue Angels SeaRey
Date: 1-12-2013
Number of Hours: 8.00
Manual Reference: 8.5 - 8.14
Brief Description: Completed section 8, landing gear
Even though I'm still waiting on a retaining ring to make the port side boot, I decided to go ahead and install the port landing gear, and I believe I can add the boot around it later. Once I had that side installed, I could hook up the tailwheel retraction and extension.
Luckily, I had seen how another builder, Tom Bowden, connected his tailwheel retraction spring with a ratchet, because I was first scratching my head... way too much tension to get it done by hand. The manual gives no hints on how to connect it, it just says do it.
Main landing gear finished and down.
Tailwheel connection to steering, retraction, and extension.
Must use a rachet to attach the tailwheel retraction spring
