Tonight, I skipped up to part 8 of section 6, and finished section 6 off to install the tailwheel. Since I'm days away from having the main landing gear on, I wanted to make sure the rear was on. There was a washer that caused confusion by not being labeled correctly in the kit, and then there was place I had to drill through for an eyebolt (marked with a yellow arrow, image 2), that the manual seemed to indicate a hole would already be there, but otherwise the manual was accurate and not too hard to follow.
