Project Blue Angels SeaRey
Date:  3-23-2014
Number of Hours:  5.00
Manual Reference:  None
Brief Description:  More interior upholstery work
I'm working on the airworthiness certification process, but thought I'd take the time to make the interior cockpit even nicer. The aileron torque tube and bulkhead gusset coming up the back of the cockpit looked very raw and unsightly. I cut out a piece of lexan the shape of the gusset, drilled holes for any bolt heads to come through, then took the Dremel and roughened up the surface, so glue would stick. I used a 36" cardboard tube, cutting a slit down one side, to cover the torque tube. I then covered them with the vinyl upholstery I used throughout the cockpit, and re-installed. Finishes up the interior nicely!
Cutting out the cover pieces and test fitting
Glueing vinyl to the pieces
In place and looking good.
