Project Blue Angels SeaRey
Date: 4-20-2013
Number of Hours: 5.00
Manual Reference: 33.13 - 33.14
Brief Description: Section 33, interior, center console continued
Section 33, interior, center console continued. Still doing a lot of trimming on the console frame to get it to fit perfectly. Made a paper template of the side covers, so I could lay it on the frame and know where to drill for the clip holes. I secured the template, then punched through with a pen for each clip hole. The clips have about a quarter inch of hang, so you need to mark the spot to drill a quarter inch above where you punched through, else the panel will hang lower than you wanted. You want to go ahead and put the clips in the covers, and push the clips into the frame holes when attaching.
I've got some more trimming and work to do on it, but overall, I'm very happy how this is turning out.
Using a template to drill side cover clip holes.
Test fitting.
Will need some more trimming, but almost there.
