All the wiring is done, so I took the time to wrap/sheath and bundle all the wire to each section it will run to on the panel. The entire avionics tray is grounded, but has so many power wires running through it, I wanted to carefully wrap all wires to ensure any future movement and chafing won't cause a short.
It may look a bit of a mess, but the wires are bundlled and secured on the tray so they'll be out of sight behind the panel and no way they can fall to impede the rudder pedals.
