Project Blue Angels SeaRey
Date: 12-5-2013
Number of Hours: 5.00
Manual Reference: Nome
Brief Description: Wiring headphone jacks
Beginning to wire the radio, so need to get the headset jacks ready. I had previously run the wire to back behind the cockpit for them, so it was just a matter of soldering the jacks on the wire… a job that still took three to four hours. If I had to do it again, I could now do it in half the time. I almost made the mistake of soldering to the wrong tabs; the tabs are on the opposite side of the contact it connects to, not next to it. I’ll eventually have make a plate to mount them to, but at least now I can test the radio after it’s wired.
UPDATE: Funny I mentioned if I had to do it again, I could do it in half the time, because I have to rip it out and do it again. I was only using 2-conductor shielded cable, and used the shield to carry the ground back, which is a no-no. Even through the ground is connected to the shield on the avionics side, it still needs a dedicated wire to run within the shield. For a proper stereo connection, I have 3-conductor shielded wire on the way, and will re-wire. The radio still worked this way, but would have not been absolutely clear of extra noise.
Beginning the solder job
First jack is done
What they look like finished, ready to mount
